bill patton
Active Member
I'm building my 74 dart swinger..all lights,gauges and signal indicators and switch worked fine..i removed the cluster and painted it and installed leds bulbs...put in a new dash pad..changed the dash from green to black..put the column back in place...now the lights work except for the turn signal indicators and when you crank the car the started stays engaged until you pull the battery cable....same column as before,same cluster...i welded in new classic industries floor pans..have new carpet,door panels,headliner,etc...cant firgure out what happened in the dash..any help will be appreciated...thanks
