Wx is FINALLY starting to warm up, although a few days ago it was below 28F at 7AM when I got breakfast.
The object is to get the so called "new boat" (dirty aluminum about 63 Sea King 14ft in good enough shape to be safe, and get it on the water to find if it handles and has the speed I expect, or look for something better. I did decide to cut a new dash, and lay it over the old wood one, which, while ugly, was sound. The support braces under the bow deck were FLAT layed 1 x 4" unfinished!!! pine boards. The center one, under the holes for the horn/ bow light/ etc leaked and it was rotten. I used aluminum under there, so no wood.
I got some white oak and got the transom done earlier this winter, it will go in tomorrow, I hope. Still need to string steering cables and install remote throttle/ shifter which won't take much.
Today I junked out the Sea King trailer which came under the "new" boat as it was in bad shape. I did score some useable rollers off it and little else. It was old and rusted, and I don't need it.
The trailer under the "new" boat is likely built for a 16', and came under a junker, last year it carried the 12' Crestliner. The trailer NOW under the Crestliner came with the 2 boats, 2 trailers, and 2 motors that encompassed the "new boat" deal. One glass boat of that 2 went to the dump. Put new lights on the "old" trailer, and need to do same to the "new" trailer. Tonight I finished up reworking the rollers and getting both trailers adjusted to both boats.
I might just have these ready before "the weather" gets here
