I'll have to hunt that pic. Its here somewhere. Meanwhile...
They're all about the same.
Middle slot is 12 volts.
The other 2 are pretty obvious. The copper trace going to the various gauges is the 5 volt path. Ground is what it is, chassis ground. This means the IVR nor anything else on the panel will function properly unless the inst housing is grounded to the car. A permanent dedicated ground wire is strongly advised.
