66durgederp
"pull hard, itll come easy"
from what ive read *takes grain of salt* API SM is federally mandated to be no more than 800 ppm zinc/phos, API SN is 600. the happy zone for flat tappet setups is 12-1400, once again, this is what ive read from numerous sites *more salt* and books. Now a product that Ive been running thats readily available to me is schaeffers oil, and their "moly EP" additive. I run the 10W-30 diesel spec and the 15W-40. Both are CK-4/SM spec. From what I assume, if the label says SM, its max 800ppm zinc and phos. Otherwise the EPA would be all over em, at least I would think. Schaeffers figured out how to keep molybdenum sulfide in suspension within the oil (back in the day it would settle into the bottom of the pan) and get it to go where it needs to be: cam lobes. This is supposed to accomplish what the zinc and phos used to. I have 2 big block powerwagons, both run hughes bumpsticks and crest 300 lbs on the springs. Since install ive racked 10K+ on both rigs and havent had a single issue, so it must do something. Hughes engines sells their own moly additive thats a teal/green color. Its literally schaeffers with a hughes label. Its worked well for me. also, look at valvoline "racing" oil - they spec API SN right on the damn bottle, so their claim to have more zinc is extremely hard to believe.....otherwise they are breaking federal law....right?
