Dipstick tube gromet
Ammo
South Florida
For a1974 dodge dart sport 360.
Does the dipstick tube have a gromet going to the block.
I got a good size leak and trying to find out what else could be leaking besides the oil pan gasket. Thanks
Ammo
I believe there is an O ring. Was on my 72. May want to check shifter shaft seals too.
Good luck,
Pat
my mopar chrome replacement one had no grommet, i actually had to grind it down a bit to fit in block, oem may differ though
Best way to install a new one is to freeze it overnight in the fridge. It will slip right in then warm and expand.
Same deal for bearings but the opposite. Warm them in the oven and cool the other piece and they drop right on your pinion or such. Pressing things in or on is not always needed!
