Disc brake setup
dachiefs
Active Member
Lawrence, Ks
Hey guys, a guy I know has what he says is a complete v-8 K-member with disc brakes from a 1970 duster...does this sound legit? If so, will it work on a 1972 duster....thanks
sure. they came that way.
should be small bolt pattern, 4 piston KH calipers
Thanks for the info, if I want to change to big bolt pattern, I should justbe able to put BBP hubs on it?...right?
no...you need the bbp upper A arms, a disc brake spindle, and a bbp disc. all available from 73-up
