I found two spare mopar electronic distributers with vaccume advance and i took them apart and looked at the plates that the slots are in the thing the ignition rotor sits on top of. I read the numbers on the back of them and one says 15L on it and one says 13L. I was told that by reading these numbers you could tell how much mechanical advance they give in the distributer. Right now in the distributer i am running on my engine the mechanical advance is 28 degrees wich is too much, when i run 34 degrees of total timing on my 360 magnum it gives me an initial of 6 or 7 degrees. I am hoping one of these set of slots will allow me to run a higher initial timing. Does anyone know how much mechanical advance is in the 13L or 15L?
