Distributor Clamp Upgrade
DonPal
Tolland, CT.
Slants eventually upgraded from a slotted distributor plate to a distributor clamp style similiar to small blocks.
Slotted distributor clamps limit the adjustment so if you pull a distributor & reinsert it on other than the perfect gear tooth...... adjustment is near impossible.
Since I can get small block clamps easier than slants I'd like some dimension of a small block clamp to see if it would work....a picture with dimensions would be helpful.
Thanks.....Don
Thank you cavemanmoron for a reply.
I have previously search Slantsix.org & am following a related thread with no success.
I have also searched the Slant six sub forum.
I decided to try this area because early A body V8 people might be here willing to check dimensions on a spare clamp they might have ....which might have more success than discussing getting V8 dimensions at a slant forum.
If I get dimensions I'll add it to the Slantsix.org distributor clamp thread.
