A340
When I rebuilt the 340 engine 2 years ago, it had an Accel dual point distributor w/o the vaccum advance on it and ran decent. After the rebuild I installed a brand new Mopar Electronic unit in the car.(with vacuum advance) The car had only about 100 miles on when I took it to the Nationals. During the cruise night in Heath the car died and had to be towed ($$) home. The Orange electronic box had went bad, so I purchased a new one from NAPA.( Car runs OK no gas smell at the exhaust at idle. ) A year later, while leaving the Nationals once again, the car dies. Tow it home once again. Had a spare orange box but didn't work. So I pulled the distributor and put the Accel back in. Only to find the brand new MSD coil had gone bad! At this point I left the Accel in, timed the car back to 32 degrees, and the car seems to have a little more power at take off than the Mopar unit had. (No vacuum advance) Now the problem is the car stinks like crazy at idle from the exhaust. If you walk behind the car you will smell like gas all day. So do I take a chance and put the electronic unit back in and cross my fingers, or am I better off leaving the dual point in and hoping someone can tell me how I need to correct the gas smell from the exhaust at idle? Haven't wanted to mess with car that much since. Getting a little bored with winter now.
