With that build you want a fast, short curve. I'd start with no more than 18* crank degrees in the dist, and maybe start with the second to lightest springs in the kit.
Play with it a little to see where you are. Try about 36* total advance, which with 18* in the dist will give you an initial of about 18 initial.
If it kicks at the starter or pings at part throttle, you'll need more spring and or a longer curve.
If it tolerates it well, try the light springs.
"Back when" I ran a tach drive dual point in my RR with a 480 lift erson cam, I ran the thing for awhile with NO springs. The drag on the points pulls the advance back for starting, and when it fires, it's "all in." Back then, I ran 38-40* total advance. Better fuel, no ping.
Without running the thing on a dyno to optimize it, you are just guessing.
