Distributor vacuum ? thermoquad
rustytoolss
Clinton, Ohio
Should I use manifold or ported vacuum to my distributor ? Also I'm using a 1982 Thermoquad, which port would that be ? Thanks
Ported vacuum, There may not be a ported vacuum tap on an 82 TQ. Ported is usually a horizontal slot in the throttle bore.
ported will be above the throttle blades...full vacuum below.
I cannot imagine that there would not be
Ported vacuum ca be found as that one dead vacuum hole at idle. Rev it up, it starts sucking.
My 84 TQ, I believe goes to a goofy coolant connector, up on the rad hose. Keep in mind mine is a pure stock app for a 84 D150 360 4bbl.
