tanis
Thats what they say.
But here's how that might work. Say you have the initial at 20* and the power-timing of 34*@2500, just as you say.That might work out so the mechanical is coming in at a rate of 1* per100rpm and starts at 1100. Suppose you have a 20* Vcan, and it's all in by 13inches.
So it idles at 20*. You step on it a little, and the semi-lumpy cam starts to build vacuum. Say it reaches 13 inches by 1300rpm. Now you have the initial 20, plus 2*centrifugal, plus 20vacuum =42*.
So you rev it up to 1800; now you have 20 plus 7 plus 20v +47.
So next you rev it up to 2500; now you have 20 plus 14 plus 20v +54*
Now some engines like this kind of curve and some don't. You can adjust the Vcan to delay the Vcans all-in point, a little bit, but by 2000 to 2200 most street cams have vacuum-peaked well past the all-in point.
Ok so lets start making the engine work. Say you are cruising in 2nd gear @2500, so starting from 54* total. With 3.55s and a 904 you might be doing 38mph. So let's roll in to it.So you press gently, and the timing stays at 54, and maybe you hear the dreaded spark-knock. Let's say you don't. Slow back down to 2500, and step a little harder, say hard enough to open the powervalve @11inches vacuum. Your vcan might drop out at a rate of 2* per inch, so at 11 inches it drops out 4* . So now your timing will be 54 - 4 = 50*. This will for sure knock. So you will have to press harder, to drop more out, but now the secondaries are opening and knock is still evident. So you floor it and all the Vcan timing drops out and you are sitting at 34* phew!
So what to do. Something has to be done.
Most sbms I have worked on are fine with 20initial, and are fine with 34* powertiming, and fine with 20 in the can. And are even fine with 54* at cruising speed. I have seen some like 60plus degrees at cruising speed.The problem is blending these 3 to make it driveable.
Well I really like to tune with the Vcan, cuz it let's me make some decent mpgs;so I bring that 20 to 22 degrees in as quick as possible. If you have a high cr the engine likes that. So for me I have to delay the power timing somewhat and usually start with a little less initial. If you have a slightly loose TC that stalls at 1800, we can easily sacrifice a bit of timing below 1800 and never even miss it. So lets back up the initial to 14*. We need the powertiming to be 34*, but let's delay it to 3000rpm, and let's say it starts coming in at 1000rpm. So the centrifugal curve will be 20* and 2000 rpm;that makes, 1* per 100rpm. And the can will stay as it was;20*,and dropping 2*per inch, starting at 13inches.
So idle timing will be 14*. Again at 1300/and over 13 inches vacuum, the timing will be 14 + 3 +20v =37. Thats just 5* less than before, and no detonation. At 1800 light throttle, the timing will be 14 + 8 + 20v = 42, and all quiet. At 2500 it will be 14+15+20v=49*. By 3000rpm the total will be again 54*. So far so good.
Now again lets roll into it and by 11 inches of vacuum @2500(same as before),timing will be 14+15+16v=45*. This is again 5 degrees better. And when you floor it, all the vacuum timing drops out and,you still have the 34 by 3000rpm .
This 45*Part Throttle timing at 11inches of vacuum may still be too high, but,with a little tuning of the Vcan, you might find that the rattle disappears.
If you value MPGs, you have to give the engine some serious cruise-timing.
Long story short; every engine is different.It's up to you to figure out what she wants, and when she wants it, and under what conditions. Then, since the dizzy is not programmable, you have to try and hit as many marks as you can. Since the powertiming is more or less fixed, one or both of the other two(idle and cruise timings,depending on which you value more),may have to be compromised. It's rarely possible to hit them all perfectly. I compromised the idle timing, and set mine to 12/14. And I run powertiming of 32 /34(alum. heads), but it's a two stage with a kink in it's rate, at 2800. It brings in about 16* by 2800 and then slows down bringing in another 3*or4* by 3200/3400.Then I run a 22* Vcan, bringing it in as fast as it is able. And since it still is not enough cruise timing(there's the compromise again), I installed a Jacobs Optotimer which allows up to 15 additional degrees of timing, depending on how it get's set up.While it's theoretically possible to run a total cruise timing of 14+20+22v+15timer= 71, I have never set it up that high. I typically run 14+12+22v+8timer= 56*of cruise timing at 2240rpm/65mph.
I know, clear as mud.
If your pistons are down in the hole., and you have no squish/quench, this may all be so much mumbo-jumbo, as low-cr engines have totally different timing requirements.
