Do I need a deeper pan to shift above 6500rpm?
RockinRobin
Corsicana, Tx
727 Torqueflite in high 9 second drag car reverse pattern manual valve body, slightly deeper than stock pan
I have shift light set at 6500rpm but datalog shows 1-2 shift actually happens around 7000-7200. Am I running out of fluid? Do I need a deeper pan?
No, but it would be a good idea to run as large of transmission cooler as you can get.
Corsicana, TX, Collins Street Bakery, Love their Fruit Cake
Tom
Hopefully your trans isn't slipping 5-700 rpm at the shift points. Type F fluid has been a popular choice to firm up shifts and performance synthetic trans fluids tend to last longer because they are more resistant to heat and breakdown. I also preferred 4.2 kickdown levers.
If your shift lite comes on at 6500 and your data logger show 7000-7200, it means the engine revs 5-700 rpm by the time you physically react and the transmission actually shifts. There will always be some human and mechanical delay but the actual shift rpm should be determined by the rpm that the engine performs best at, unless you want to shift a bit lower to be easier on the engine or run a bit slower but keep a little ET in reserve and shift a bit later if needed. Like if you slip or spin off the line. Set your shift lite accordingly.
Theres a lot to be learned from data loggers and playback taches. They show what actually happens rather than what you think happens.
We're "human!" I loved my Autometer playback tachs.
Of course, in addition to a trans cooler, a higher capacity trans pan with the corresponding extension couldn't hurt either. There would be more fluid to absorb and dissipate the heat.
I don’t think you’re running out of fluid. But I certainly would put a deep pan on it and a bigger trans cooler.
How hot you talking during round robin?
Sometimes after a round it will get up to 220. I like to run down the track with it between 150-160
