adamfeber
Title should be: "Do I need a STALL torque convertor?" - I do not see anywhere to update the thread title.
Here is my setup:
- 340 with 9:1 compression
- Lunati Bracket Master cam - 292/292 duration and .480/.480 lift. (RPM Range 2000-5500)
- Vintage Edelbrock TM-5 Tarantula Intake (got it at a swamp meet a while back, plan to upgrade to air-gap soon)
- Edelbrock 600 cfm Carb
- Mopar Performance Distributor, MSD 6al box
- Unknown headers
- 727, shift kit, stock convertor
This is a project that was started 10 years ago and then put aside (life got in the way) - the car has never been on the road. I am just picking back up and committed to getting it on the road.
Prior to abandoning the project years ago, I could not get it to smoothly go into gear without the car just bogging down and wanting to die. I was told it needed a stall convertor so I purchased a B&M Holeshot 3000 stall Torque Converter (Part # 10425) but then stopped the project before installing it.
I was following another thread with a similar issue and it appears that this is usually caused by one of three things - needs stall convertor, carb issues (not my case), or vacuum leak (possible).
So I guess my main questions are:
- Looking at my engine setup (above), should I need a stall convertor or should I consider other causes before pulling the transmission.
- If I do need a stall convertor, is the torque convertor I already have a good fit for my configuration: B&M Holeshot 3000 stall (Part # 10425).
Any help is greatly appreciated. Really excited to pick this project back up and get it on the road - 10+ years later.
Here is my setup:
- Unknown headers
