The pivots rotate only 180°. Pressure from wiper, etc.., cause directional wear. There's only 2 shirt bronze bushing in a cast housing about 3" long. Mark the bottom of the potmetal housings with a sharpie b4 removing. Apply seal kits with zerks. Add grease and reinstall rotated to your marks on to. Forces are now against a less worn bushing wall. Instrument panel R&R procedure is in a factory service manual. Issues owners encounter include breaking pins off printed circuit boards, loss of neutral safety adjustment after column was lowered. Improper routing / difficult reconnect of speedometer cable, etc... Let's go ahead and grease the speedo cable, replace light bulbs, everything we can to prevent a return trip while we're in there. Clean whatever crud from the square drove Port on back of speedometer. Procedure in the manual likely states disconnect speedometer cable early on. I don't I put a short stand under the right front. Reach under and release the speedometer cable from a sheet metal tang under the drivers seat. Once all the screws are removed from the inst panel pulling a bit of speedo cable through the firewall grommet into the cab practically pushes the inst panel out.l of the dash. It serves as a helping hand while I carefully defeat that round harness connector that often breaks contact pins off circuit boards. If those wires are combed out straight enough, the black plastic will come away from the board leaving some or all of the female terminals. Those can be removed individually. Don't allow the wires to exit the slots in side of connector. Keep them in proper positions. I wrap white tape around the thing, no worries. In the end, speedo cable should route right back the way it was. If you do need to get a arm/hand behind left side of inst' panel,, one screw out of the fusebox, drop the headlight switch.place something to sit on in the doorway. Right pivot is behind the radio. Shouldn't be a problem there. Happy moparing.
