just replaced my 5.2 to a 5.9 in my 98 dodge ram due to it throwin a rod, after putting the new engine in i had a bad ground and one little ground on the passenger side of the truck coming from the fire wall the block started to smoke, this was on the first inital turning over of the motor fixed all my grounds motor does not turn over fast like my brothers 99 ram, used his battery still slow, also have no spark, could i have burned up the coil or any other sensor? could the crank sensor not be grounded well to the block because i painted teh block? everything worked fine before pulled, also still have the computer from the 5.2, should still work with that computer correct? any help is appreciated thanks,
