Does Anyone Make This?
mopar_mudder
Active Member
Wisconsin
I don't think so but does anyone make the panel that is between the A pillar and fire wall? If not looks like I am making and fixing.
Not that I have seen. AMD if anyone would. It would help to know what you are working on.
the other questions...
what else uses the same or close enough panel?
are you doing a full boogie restore that you care how correct it looks?
how much of the panel do you need? all of it including the seams, or, are the edges good and you could fabricate the rest of it out of 16 gauge?
It is mainly the lip where the firewall attaches and about 2" up from the rocker that is bad. I can make it if I have to, it is just alot faster to replace then make and seam weld in pieces.
I have one for sale, question is when I will have time to cut it out.
