When you change the stroke length it pushes the rod further up into the bore. You have to either use shorter rods with pistons that have a stock pin height or use stock length rods with the piston pin moved higher towards the top of the piston...or both depending on what rod length/stroke you use.Can u just change the crank in an engine or do you have to have new connecting rods. Sorry for the dumb question
Yep. They have done thousands of them and they know what works.If you get a stroker crank (4.00" for example), you just have to get the correct "stroker pistons" to go with it. The piston needs to be a little shorter so that they don't exit the top of the block and knock the heads off. The simplest way to go about this is order a stroker kit from Scat (or another reputable company). This will come with the correct crank/piston combo, along with rods, rings, etc.
Good mention of rod ratio. You can get a longer or shorter rod to meet the need or target rod ratio. This can get expensive.Depends on the kit, pin height, stroke.
But most use a std rod length.
What does change ...is the rod stroke ratio.
Now that would be nice if it could be done and yet still handle 750hp NA.A lotta lotta problems could be solved with adjustable-length rods.
May be a good idea in theory.A lotta lotta problems could be solved with adjustable-length rods.
I'd run it in my new polymer block.
I read it that way too.
Lol.
You can increase compression to a point by keeping the valves closed longer. I saw a engine or two in the last coupe days that have computer controlled valves. That would do it.I'd like to have a hydraulic vari length rod, self learning computer controlled and tied to a knock sensor. This way I could run a ton of compression and race gas, or change the program and run 87 pump gas. Couple this with a vari lift lifter and have a docile cruiser and a race engine all in one.
I know, I know, put down the crack pipe and slowly back away. LOL
Dan, if you're going to spend the money on a stroker kit, don't use a 318 as a base. Sell the 318 and stroke a 360. You'll get even more cubes and better breathing heads (some heads can't be effectively used on a 318 bore).Thanks for all the replies. After reading all these 318 stroker threads i feel the need to build one. I have 3 really good running 318’s. I won’t never do it but it does sound like fun.
Really! Do tell me what cylinder head can not be used.(some heads can't be effectively used on a 318 bore).
