Door panel clip removal tool - which one
For the money the Stech one at the bottom right corner of the first page will work fine. The thin, 'blade' type will slide between the panel and the door easier than the thicker 'screwdriver' type.
Dallas
The Lisle #35400 on page 2. The Steck tool is plastic and made for new car doors plastic trim with hidden clips. The metal clips on old Mopars have to be pried on pretty good to release. toolman
I just looked at the pic and thought that one was metal. That's what happens when you don't read the description. ](*,)
Good thing you noticed it.
Dallas
I work at a auto glass center and we just use our fingers.... I use my fingers on my fish without tearing anything up. You want to make sure you have your fingers position between the clip and door .. push out not pull the cover. Pulling the cover causes the damage.
