Dougs Headers Hitting Steering Linkage
scottylack
NEW JERSEY
Finally got my headers in my 65 barracuda but now have an issue with one one the drivers side pipes hitting steering linkage. I used a 73 disc set up but I don't think that is the issue. Take a look and maybe help me with my options!
Thanks
i would shim up the engine before i took a hammer to anything. a hammer to brand new expensive headers would be my last resort.
might not even need shims. you could loosen the motor mounts at the k frame and then push up on the one side of the engine with some creative jacking. could slide the motor into a better position.
My issue might be that I used 73 duster discs. That means the control arms as well. Any other feedback welcome
try 73 center link and steering linkage . the nuts faces down I figured that out on my Duster after I modified the 2 inch tube header.
Don't think you can mix early and later A steering linkages. Whole different animal.
is center link on the right way? seen em put on backwards before... good luck shim up motor or make some special mounts..
