draging header
gopar
Active Member
alabama
is there a way to lift the front of this duster up so the driver header wont drag? going to replace it dont want to destroy the new one. will going to bigger torsion bars lift it up
Just jack up front of car and tighten the 3/4" bolt on the bottom of the lower control arm to raise the front end. Do both sides the same amount of turns. I recommend 1 turn and lower car and test drive at a time.
that was easy thanks 15 inch tires on front now to 2 birds one stone tks
You could make a positive stop bumper so it don't bottom out.
OR if MP is still making that killer RR t-bar with the big spring rate...
Or...see Bill Reilly
