Driveshaft lengths - new drivetrains
swing69
I’m just an old guy……
Central NJ
Early Driveshaft lengths (for a 65 Dodge Dart 2 dr.)
In an early A body 2 dr., does someone have the driveshaft lengths handy for the following combinations: (u-joint center to center)
small block - slip yoke 904 - 8.25 rear
small block - slip yoke 904 - 8.75 rear
small block - slip yoke 904 - Dana 60 rear
Thanks!
Why don't you slide a 904 slip yolk into the trans and measure from the center of the slip yolk to the rear axle companion flange center? Make sure the slip yolk is bottomed out the removed 2" which will allow for drive line length changes. The have a shaft made and balanced. This will be efficient... "new" & "cost effective"
