driveshaft retmoval on 76 swinger
jasonmrenda
well i am just about to drop the whole k frame with engine and trans attached but i want to remove the driveshaft first. i undid the 4 bolts at the rear u-joint and removed the 2 plates. i removed the trans crossmember. no matter what i do i cannot get the driveshaft to drop out. is there a snap ring or something i am missing? i only have my manual for the 67 and it doesnt mention anything about a snap ring or whatnot, but maybe there is a difference on the 76?
thanks again everyone
- jason
not sure on the swinger but it should be the same as on my dart sport. Sometimes you may have to push or pry the driveshaft a little forward to pop it out of the yoke then it will slide right out the back of the trans.
The drive shaft should slide right out. Just wait until you try to remove those 40 yr old torsion bars. Now they are a pain.
