[Found!] Drum/Hub/Stud assembly for 10" A-body with 5x4" bolt pattern
KlobraCuda
Lieutenant Colonel, U.S. Army Reserve
Grayson, GA
Rating - 0%
0   0   0
Seeking a replacement drum/hub/stud assembly for the RH passenger in my 1965 Barracuda.
Studs worked loose on the RH passenger side and destroyed drum, hub, studs and wheel and am finding it extremely difficult to locate a replacement hub. I have located a new 13" steel wheel and can obtain a 10" drum readily if needed, but locating a hub/stud assembly is proving to be a challenge.
Needs to work with 10" drums, 13" wheels and 5x4" bolt pattern. Also would prefer threaded for RH lug nuts.
Thanks in advance for any assistance. If located anywhere close to Atlanta I can come pick up, or otherwise will pay for shipping.
Are these what your looking for? they came off my 68 Barracuda front 10" drums. I'm in Peactree City Ga not to far from yah maybe hour depending on traffic.
They may be as long as the 5x4" bolt pattern is the same. I will check and confirm and, if so, would be glad to make the trek to PTC.
Believe it or not check rock auto.
I did, and they definitely have the drums, studs and wheels - all at great prices - but I don't think they have the hubs. If they or a similar entity does have the hubs for sale, however, please let me know. Thanks!
i think i may have one can check and send you pics
I'll be in ATL tomorrow which is halfway to PTC if these are 5x4" bolt pattern. If so, how much would you be asking for one of them? I can be reached by private message. Thanks!
Are you looking for the drum also?
Yes, if possible, although I should be able to locate a drum separately if needed.
Sorry, I may have gotten you confused with the other member in Peachtree City, but I am interested in whatever either of you might have if it will fit 10" drum and 5x4" bolt pattern. Thanks!
Ok i only hae 9" drums and a hub for a 9"drum
The hub may work with 5x4" bolt pattern on a 10" drum. If I can't obtain one locally and the one you will fit, what would you be asking as far as price?
I cang
Just an FYI. The factory "swedged" the studs, after the drums were installed on the hubs. If you try to remove the drums and/or studs, you must remove the swedging, or risk ruining the drum or hub. There is a special tool for this, or carefully use a cutoff wheel/grinder.
I will be in ATL next week and can come your way and/or have a colleague who lives in Senoia come by to pick them up. Let me know what you would prefer. As long as the bolt pattern is 5x4" then these should work.
As stated you can not put 10" hubs and drums on 9" spindles keep that in mind. The 9" hubs and drums won't fit on 10"spindles which are also 5 x 4 bolt pattern
I'm out of town and don't get back until 19th late and go right out 20th I can get together the morning of the 20th around 9 or 10am.
The 9 Inchs hubs are differents than the 10 inchs hubs(bearings size)
Th
That should work. I can make that happen. Let me know how to get in touch offline.
If you are still looking for these parts, I have right and left, everything you need. Located south of Nashville TN. Can send pictures.
