drum to disc conversion will the front track width change ?
Done plenty of drum to disc conversions but never actually measured if it changed the track width.
Even if it did it wouldn't be a problem since the front track width should be wider than the rear anyway.
I think it is like an 1 1/2 wider on each side, so three total? Here is my before and after pics, but I also changed wheel backspace...
since your keeping small pattern front track width will stay the same,you do have to change the lower ball joints,and that throws your allignment off though.
