cudajim
cudajim
I have a 74 Dart, all stock wiring and working well. My question is, what's the purpose of a dual ballast resistor? I know the top one is used to drop voltage and supply the ignition coil but what's the bottom one for?
Point me to one. My bottom resistor has a horizontal crack in it, most likely not the proper resistance now but still working.The ecu. There are a bunch of schematics available on here.
The initial Mopar ECUs were 5 pin units and used a dual ballast resistor. One side of the resistor feeds the coil, the other side feeds the ECU. On later systems, the 5th pin on the ECU was eliminated and a single ballast was used- the function of the dual ballast/5th pin was moved internally in the ECU and was no longer needed.I have a 74 Dart, all stock wiring and working well. My question is, what's the purpose of a dual ballast resistor? I know the top one is used to drop voltage and supply the ignition coil but what's the bottom one for?
Now it makes sense. I bought a new dual resistor anyway, everything's working. I also bypassed that ridiculous seat belt interlock relay by hooking the 2 yellow wires together.
