Dual Exhaust hangers and locations..
nodemon
St.Louis
72 Demon.
Where can I get the right hangers for my dual exhaust..? I purchased a used, complete exhaust and have it installed from manifolds to muffler but need the hangers and mount locations. I've looked around underneath where the muffler ends and I don't see where a hanger would mount. I'm assuming this car had duals at one time due to the headers that where on the engine and evidence of "strap" hangers near the trunk.
If anyone has pictures too, that'd be a huge help.
Thanks..!
The hangers bolt on from the seat belt bolt location.
The aftermarket TTI ones use a longer seat belt bolt and get installed there, the factory ones did not. In the pic, left side is there, the right side goes where the dimples are.
72 Demon.
Thanks..!
You only need the Passenger side. I'll look up the one I was looking at. Dimples are already on your car.
A Bodys Bolt to the floor pan Not seat belt hole There are brackets that ! on Driver side is welded to floor pan then if it a true duel Ex Car. the is a Bracket that bolts to floor pan on pass side
You can also use the reproduction hangers now.
Passenger side kit
