Dual Master Cylinder for '65 Dart
SparkyDoo333
New Member
Roseville, California
67 Valiant drum master cylinder. Just plumb the line for the front brakes into the present splitter and block the port for the rear brakes. Run the line for the rear brakes directly to the master.
I did buy a set of prebent lines from Inline tubes and there splitter. There splitter was unlike anything ive ever seen with 1 line coming out the side! I had to make a bracket. I asked if they sold a line for this splitter set up, which they do not. You really don't need it.
Yeah, it'll work, but there's no need for "all that" when you can just get the correct master cylinder to begin with as mentioned.
