They are different. You will see the Dart Sport, Duster , And Demon have 3 attachment screws where Valiant. Dart , and Scamp have 4. This is so you can't interchange them, They are angled different due to the Valiant style having a flatter quarter then the Duster. You will put a slight buckle in your quarter when tightened.
Also they are different through the years. 72-76 screw through to the outside of the Quarter and 68-71 fasten on the inside.
I am installing 72 AMD quarters on a 71 Demon. Not only did I have to weld in the marker light recess but the fuel cap recess is deeper on the 72 Quarter. If I was to use the 71 fuel neck the gas cap would be recessed into the quarter when installed. So I have one or two choices . Cut out and weld in the fuel recess from the 71 or change out the fuel neck/tube. I have a 72 fuel neck/tube so I will change out the neck/tube. Easier and no welding.
There are many little things they change on every model and year . They still do it today so you can't use parts from used cars on the new cars. Its all about the money and control of parts. You will need a three hole neck/tube with slots where it screws to the quarter, If the fasteners screw into the neck/tube its the wrong one.. Hope this helps and you understand what I described.
