[WANTED] Early a body Fender mounting hardware
Hi Rob. I have some later A-Body fender mounting hardware if that can help.
Also, your mailbox is full.
Ken
What specifically are you looking for - inner fender to fender along the top and front, lower fender to rocker panel or the nut that secures the upper rear of the fender to the hard-to-reach bracket mounted to the side cowl or all the above?
