Early A Body fuel Spillage
Early A-Body Discussions
  1. wheelsport
    wheelsport Well-Known Member
    141
    95
    Jan 21, 2019
    Vancouver, Washington
    Local Time:
    8:21 AM
    The early A body cars have long had the problem of fuel spillage while filling up.There has been much said on this forum about this problem. Modern fuel filler tubes have the smaller diameter inlet for the smaller gas pump nozzles, which act as a baffle. This baffle stops fuel burps. Our old cars don't have a baffle, which is why our cars burp fuel when the tank gets full. Layton's sells a converted fuel tube which solves the problem. However, I figured out a simple solution that costs under $5. I purchased and modified a PVC grommet that does the same thing as Layton's filler tube. The hole in the grommet is large enough to allow modern gas pump nozzles to loosely fit. I very carefully ground the outside diameter to tightly fit inside the the filler tube. I then applied Right Stuff in the groove on the OD of the grommet and then stuffed the grommet a little way down inside the filler tube simulating a modern filler tube. Right Stuff is strong enough to hold the grommet in place for a long time. The grommet sells for $4.49 at Autozone and is available almost any parts store.
    https://www.amazon.com/dp/B000C5I49C/?tag=fabo03-20
    • Thanks! Thanks! x 3
    • Like Like x 1
    • 66340SEDAN
      66340SEDAN FABO Member #3649 FABO Gold Member
      21,670
      14743
      Nov 20, 2006
      Minnesota
      Local Time:
      10:21 AM
      Do you have a picture of it installed?
      • Like Like x 1
      • toolmanmike
        toolmanmike Moderator Staff Member FABO Gold Member
        62,487
        51748
        Jan 18, 2006
        Iowa
        Local Time:
        10:21 AM
        Thanks for the tip. It's a cheap and easy fix.
      • gdizzle
        gdizzle Well-Known Member
        950
        116
        May 25, 2015
        los angeles
        Local Time:
        10:21 AM
        Sounds like a great fix. What I do is just turn the nozzle sideways and put it in. Then listen carefully as it start to fill.
      • wheelsport
        141
        95
        Jan 21, 2019
        Local Time:
        8:21 AM
        That doesn't always work. I know from experience!
        • Agree Agree x 2
        • dibbons
          dibbons Well-Known Member
          5,149
          3133
          Nov 6, 2009
          La Paz, B.C.S., Mexico
          Local Time:
          8:21 AM
          Make sure to keep it recently waxed under and around the gas cap on the quarter panel (may help reduce staining when spilled).
        • cudamark
          cudamark FABO Gold Member FABO Gold Member
          9,131
          1552
          Mar 14, 2009
          San Diego
          Local Time:
          8:21 AM
          Yup, and a rag in your other hand to attack the spills immediately.
          • Agree Agree x 1
          • emsvitil
            emsvitil Well-Known Member
            843
            1050
            Mar 14, 2015
            SoCal
            Local Time:
            8:21 AM
            +1
          • 512Stroker
            512Stroker We are all here because we are not all there.
            3,130
            2477
            May 30, 2016
            Freedom, MO
            Local Time:
            10:21 AM
            +2
          • wheelsport
            141
            95
            Jan 21, 2019
            Local Time:
            8:21 AM
            Here's a photo.
            • Like Like x 2
