[WANTED] Early A body trans crossmember
What do you consider reasonably priced?
I have 2 crossmembers - one is factory original including minor surface rust and dirt out of my 65 Barracuda; the other is from my 65 GT that's been modified to allow the passenger side exhaust pipe on a dual exhaust setup to sit close to the floor pan the same as the driver's side. Has been blasted and painted black and a new poly transmission mount from Poly Bushings installed
what do you want for them, I was looking for one to modify
I got one in a box somewhere, bought it but Ill never use an extra. Let me look.
looked but couldnt find it, ill post it up when it turns up. Dont hold your breath.....
