[WANTED] Early "A" Inner Fender
eekvonzipper
My Member is Legendary!
Cadet, Missouri
I discovered this Rotted Section of the Right-Side Inner Fender when I pulled the Motor
out of the '65 Barracuda... Is it possible to find one?
I really just need a small section if Anyone can help.
Thanks to All!
Eric. I may have that small of a piece. I thought you wanted the whole inner fender. . I'm getting close to pulling out the engine on this parts car in the next week.
But if someone else has it , please don't let me slow things down.
You can make it smaller than that!
I can't just put a flat piece there because of the "thumbprint" at the bottom. otherwise I would just weld something else in there.
I can wait, my motor is still waiting on a Cam and other things for awhile.
bummer, I got the other side ready for the trash on Thursday....your side was cut at that point. Its hard to work on that piece as the inner is spot welded to the underside and there is very little clearance behind it to cut, maybe with a wheel on a grinder? . Hit it with a wire wheel and see what damage you actually have. May just be a little crack that can be welded and filled/painted. a whole lot easier than removing a patch and then welding 10x the distance.
Shock tower support behind the inner fender, you can see the spot welds for reference
Crappy photo but if you line up the weld holes you get a good idea of how thinks align
You might check with Lee Robinson. He has a LH one all cut off and ready to go. Maybe he has A RH one too?
Let me know if you think this will work for you. If do I'll work on getting it off.
I have the small window track off also.
