[WANTED] Early Carter BBS (Rod Activated)
CommieHook
Member
Hot Springs, AR
Rating - 0%
0   0   0
Hey guys, I am looking for a good Carter BBS to put on my 1965 Valiant with the 170 in it. The one I have on there now leaks to the point where it scares me sometimes.
Anyone have a good pull they want to sell?
Thanks!
CommieHook
if you have the original carb -- you might be better served to refurbish that one. Reman units from the parts stores are questionable at best. if your throttle shafts are good the rest of the unit is easy to do, Lawrence
