dartfever
Have a 383 in a 73 dart with eddy rpm heads. Switching from an comp cams xe274h to a xe282s. Will the springs that come with the eddy heads handle this cam? The seat pressure is higher on the eddy springs at 120 compared to the recommended springs from comp at 112. Unfortunately, eddy doesn't give an open pressure rating. The comps are 355.
Also, what practice do you guys follow for sealing the intake on big blocks? The parts guy was saying we have to use the intake gasket and belly pan. I think some rtv sealant and the belly pan would be the way to go.
