Hello, I’m putting together a 1990
360 that came to me with the famous Edelbrock RPM Air Gap intake. I’m trying to figure out how to plumb it for e heater hoses. The prior owner had a hose nipple here:
That seems weird since then the hose would have to cross over the radiator hose. Other intakes often have a nipple here:
The problem with that is that the hole is smaller, like maybe 7/16”.
I put a plug in the threaded port on the drivers side of the thermostat housing along with a vacuum port behind the carburetor base. Is the smaller water port on the right side of the t-stat housing big enough to serve the heater? I don’t have a functioning heater in the car but would like to start making things work on the car.
Is it common to use the port in the first photo ?
