j par
Remember though crappy gas will cause problems in any carburetor.
And up near the nice cool wind of the hole in the hood...Hot soak issues with stock cast manifolds. ( Fuel evaporation). A insulating spacer helps. Aluminum intakes are even better. J par's tunnel ram wouldn't be an issue. The carbs are a foot away from the heat. Lol
Remember though crappy gas will cause problems in any carburetor.[/QUOT I hear that!!!!!
Which wire do I connect it to on the alternator?I use the field wire from the alternator that is switched....close to carb.
