Edelbrock RPM 340 Heads
They are supposed to be factory replacement, But I don't know if you do. Someone will be along pretty soon to let you know!
If you've been running the N9Y it should work fine. Are you making any other changes to ignition or carburetion?
Your answer is in the Edel. instruction sheet(s).
