my5thmopar
Life Long MOPAR Owner
After fixing a ignition issue and intake leak, I need to re-adjust my 1406 tuning. I have all the basic adjustments made but, have one issue. During cruise mode I get a slight flat spot. Meaning any steady speed and then I slightly increase throttle (I mean very very light throttle). I get what feels like a lean condition. I don't think it is the idle circuit since I adjusted it a couple times.Once I push more into the power mode, it goes away. I can either rich the cruise mode up one step (24) (I started back at 1 stock). Or I can bring in power mode with a stiffer stage spring 7/8. Small cam and plenty of vacuum. Both seem to fix the issue....so my question is...does one have an advantage over the other. Performance, economy or drive-ability etc? What do ya think?
Thanks Craig
:scratch::scratch:
Thanks Craig
:scratch::scratch:
