FiTech dual quad here.
FiTech has been extremely helpful, and the times I needed to call it was no problem calling and getting an actual person on the phone.
Tbs require a constant 58psi.
The ecu controls the pump with pwm (pulse width modulation), basically slows pump at idle, ensures pressure throughout driving conditions.
Based on that, I went with the corvette filter/regulator.
Each tb has a regulator, if you want to go that route.
They sent an in tank pump with a regulator as well.
There are plugs for the tb and pump regulators, which I installed.
I also ran a harness and a relay for a future regulator, if needed/wanted.
Turn key to run, pump primes the tbs, tbs squirt a bit of fuel, as intended, starts immediately every time.
One exception, it's butt cold out, I'll turn to run twice to get an extra squirt.
I ran it with carbs on the tunnel ram for a few years, would not start immediately, every time.
I expected, heck, I prepared for an external regulator, however it has worked as designed.
No issues with fuel psi, and it's a different animal with the tbs.
Tunnel ram keeps ecu away from underwood heat.
Just reporting the facts/results from my experience.
Efi is definitely not for everyone, not needed for many, and more importantly, it's not a simple bolt on swap and go.
Wiring, power, grounds, fuel, everything has to be considered and redone.
We did Power Tour as well, 2,500 miles round-trip, quick math, based on a $4/gallon average, we got 23mpg.
We actually met another guy running a bb chebby dual quad tunnel ram FiTech on the tour.
