Electric Choke Conversion Kit - CU1231 on a 66 225
Jayman62
Ambler, PA
Does anyone have a photo the can post of the proper orientation of the 1231 electric choke on their actual engine. Mine is a 66 225 engine. I assume I have it oriented correctly with the contacts facing the front and the rod facing the firewall, but as they say a picture is worth a thousand words. Any advice on how to properly set the tension of the rod so it closes the choke plate fully would be helpful. Also should there be any sort of spring that keeps tension on the fast idle cam? My cam seems to be very loose and just sort of flops around? I have a Holley 1920 auto trans no AC. I see in the service manual the photo of the Holley 1920 has a staging spring my carb does not have that, do some 1920's not have that spring?
Thank you,
