Electric fan
I used an Excel spreadsheet to capture the dimensions of an A-Body engine compartment. Each square is 1/2". The WP is from a '68 so is the shorter iron pump. Add 3/4" for a modern aluminum WP. I have seen radiators that do not mount flush with the core support thus taking up the space that is so precious between the radiator core and the WP fan and pully mount. Careful selection of components is needed or go to a pusher fan which is less than ideal.
Okay fellas here's what I ended up with I looked in another thread on a body's only this thing is such a wealth of knowledge thanks to all you fellows and I found a short nose clutch fan I ran a five blade fan off a w150 truck I found at the junkyard thing seems to cool real well running good I've got about an inch between the end of the clutch fan and the radiator so I'm going to let her eat we'll see what it does
