Electric pump mount 70 Dart?
dustoff440
central fl
Looking for ideas on a electric fuel pump mount near gas the tank. Don't really want to be able to see the pump from outside of the car. Is it really important to have the pump lower than the tank??
Electric pumps are generally not "suckers", more of a pusher as most do not create much of a vacuum so they need to be mounted at or below the fuel level....
I just finished adding a electric pump to my 66 Dart.I also put a sump on my orig. tank.I made a bracket to hang the pump level with the sump.I need to take a pic.
Oh,I also used the black flex line with fittings,cheaper than stainless.
