As for your alternator...
I found this...
So since one of your field terminals is grounded it is fair to say that at one time the VR could have been this type...
You hook the ign terminal to the run side of the ignition switch and the Fld side to the other non grounded field terminal on the alt.
This verys the strength of the field and regulates the voltage depending on the load.
Can the VR you have do the same???? I just don't know.
I found this...
