Electrical issues
mopardart44067
visalia,ca
Ok I have 73 duster.having electrical issues with dimm8ng lights.no dash lights no turn signals.they have no flash in panel no arrows light up and no flash at lights.no relay click only lights that work are taillights.headlights.gear selector and radio.turn8ng dimmer works a little on dimming but go to far either way they go out.i also have to turn ac selector on to start car.found that out after month of using push button and key switch.one day happened to switch ac on car started rite up with key first time since I bought it.theres other issues 8m starting with these.and all fuses look good.
WOW. Multiple issues!!
Start by reading the MAD article which gives a pretty good overview of the main power distribution
Catalog
Do you have a FACTORY service manual? If not go to MyMopar and download one free. Some of them over there........including the 73.........came from efforts of the guys here
MyMopar - Mopar Forums & Information - MyMopar Tools/Reference
service manuals:
MyMopar - Mopar Forums & Information - Service Manuals
Also from that site grab the AFTERMARKET wiring diagrams, CAVEAT: These are somewhat simplified from factory, but are easier to follow. They do NOT always show all connectors and options
MyMopar - Mopar Forums & Information - Mopar Wiring / Electrical
DIMMING LIGHTS:
Several possible causes, from a lower power alternator that is "sagging" at idle, to bad connections and grounds
DASH DIMMER: Dirty or damaged, it's a simple rheostat on the light switch. Sometimes you can clean them simply by vigourously rotating the knob many times, sometimes it must come out to be cleaned, and otherwise replace it
Frankly you car might be a candidate for rewire
AC on to start may be previous owners anti-theft set-up ?? GOOD wiring diagrams, test light, volt-ohm meter, and time are your best friends for other problems.
That might be if AC has been gutted. As we discussed last week or so, disabling the start wire is a "no starter" LOL for anti theft. Most thieves likely know how to jumper a starter, and if they show up to tow it, that's a non issue
If the front park lamps dont work at all, they may have lost their ground connection. Look for black wires attached with sheet metal screws out at the radiator/core support.
