I'm switching toan electronic ignition from points.. I bought the pro form kit that comes with a single ballast/dist/module. The instructions are terrible and I'm a bit confused. My question is the original setup called for the ign.2 wire from the the ign. switch to go to the ballast resistor, and the start wire to go to the starter relay. In the new set up the want the start wire from the ign. switch and the ign.1(run wire) wire to go to the ballast. problem is they don't tell you what to do with the ign.2 wire from the original set up. Do I send it to the starter relay?
thanks.
thanks.
