My buddy needs help to pass the test at idle. Any suggestions. It may be running a little fast. Timing is 20* at idle. 40*at 3000. This is at Phoenix Arizona. Any and all suggestions appreciated. Thanks. Kim
He is trying to get license plates for it. It’s a Canadian car. 73 Cuda 340. 1970 340. It has about 100 miles on it since I built it. 10.5 measured compression. Speed Pro pistons. Speedmaster cnc heads. LD340 intake. 650 Brawler double pumper carb. Howards cam. Complete TTI headers and complete exhaust. 4 speed car.
Slow the idle and lean the idle mix. It's only the HC failing at idle, and not horribly. 900 instead of 400.. Dead cylinders or other issues would be much higher I think.
Having the engine super hot is definitely a good idea. I'd be running a 205 thermostat to ensure a pass.
Now that makes more sense!
It boggles my mind a bit why an engine that heavily modified is being tested to a factory 1973 emission standard, but whatever.
The idle will have to be leaned out a ton, and it will need to run HOT. The double pumper likely isn’t helping, even at idle.
It’s not gonna like it. Lean on the mixture, retarded on the timing and about ready to overheat.
Not horribly? It’s more than doubling the hydrocarbon output of a factory 1973 engine. ‘73 was still pre-cat and all that other garbage, that’s a pretty high HC count to begin with.
Now having the engine specs it makes sense, that thing is probably close to double the horsepower from a factory 340 in ‘73, so moving twice as much air and fuel too. Shouldn’t be that rich, but idle isn’t where that engine is happy.
Makes senseThe smog guy that I have been using for 20 years has me put Chevron or Shell gas in the tank and drive the car for at least a half hour. He makes sure that the car doesn’t sit very long before he tests it. This was for my old 1982 Mazda B2200. My pre-1975 cars are smog exempt.
It is the ign timing, too much. It is doing two things: increases the oxides of nitrogen & increases hydrocarbons.
For the test, he should reduce init timing to about 0-4* BTDC & disconnect MVA if he is using it.
Retarding the ign makes the burn hotter, which reduces emissions. Same with lower CRs, reduces emissions. The fun police.....
Yes, just lean it out. If it has a PCV valve, leave the hose attached and just pull the valve out of the grommet in the valve cover and lay it loose on the top of the valve cover(for the test only).I say not horrible because I've seen a stuck injector cause a reading over 10k. A friend had a car with a kjetronic that was slightly out, and read 3600. We adjusted idle mix from 12.3 to 13.7 and it cleaned up to under 400.
For a cammed small block, 900 isn't that bad IMO. It'll need leaned way out, but it'll probably run there. I'd try it with a nominal idle timing. Too much advance will push up the nox, not enough will increase CO.
I don't see a nox reading, so I might be inclined to keep it at 20 and just lean to max rpm, then lower the idle as much as it can be while happy. I'd also make sure the pcv is good and maybe even cheat by letting it suck clean air...
