Engine Block long term storage
snowmobiler7c
Newport Mi
I have a fully machined 360 block that I am not going to be using anytime soon. What is the best way to protect it for storage? Should it be completely coated with a light coat of grease(like wheel bearing) and then covered with a bag? I could coat it with motor oil but would that be good enough? Thanks for any input.
Mark
Hey Mark;
I've stored engine blocks freshly machined for over a year with a light coat of WD-40 double engine bagged. A cool dry safe from being bumped. A spot free from tearing the bag open.
The day I prep the block for storage is a dry day. The lower the humidity the better. Consider it a mandatory setting for storage prep.
I usually grease or oil the cylinders and mating surfaces with grease on old and new blocks but usually at least paint the new ones some.
Hey Mark;
Glad this worked for you WD40 generally in pretty corrosive
Believe it or not I still have engines in storage from 30 years ago in 55 gallon drums with waste oil. They are at a friends and he has the room.
thanks guys, no way im getting a block in a 55 gallon drum. Floor space is already at a premium in my barn/garage lol
