engine compression to furl octane?
74slnt6
Canton, Ohio
I have a 440 i want to make streetable... what is the highest you guys would run on compression to be able to have a engine that runs good on premium pump gas? it has a set of edelbrock aluminum heads that will be installed on it...
74slnt6,
It has to viewed in a slightly broader context. Check the thread: 'compression vs octane' in performance issues.
Andrew
