Engine cradle
Larry Tomlin
Orange Texas
Built my engine cradle today out of wood, works really well. Not fancy though.
That's a little more elegant than mine. I just used scrap that was sitting around. I whipped this one out to pick up a motor in the back of a truck. Later, I added legs so I could take the motor off the engine stand, because I needed the engine stand for another project. The motor has been on and off since then; now it's back on, sadly, although it's all painted and dressed up.
Yes sir.Total length is 55". From front of engine to cut out at transmission is 21". Opening for engine to set in is 8 3/4" inside measurement. Sides are 2x12,base is 2x10, cut out is 4 1/4" deep. gusset blocks are 5 3/4" on 45 degree angle, 4 casters which support 200# each. Hope this helps.
Thanks, I could have used those numbers. I like your design with the transmission support much better than what I cobbled up. My transmission is resting on a folding table, which happened to be exactly the right height to slide it onto from the tailgate without any lifting. Not lifting was a priority, since my helper had a bad back, and I didn't have a hoist available at the time.
Your are welcome. I rigged up a 12 volt winch with double line to lift my engine. I understand about the lifting. I am too old for that. Thanks for the reply.
